I have a 1953 Chevy 3800 with a 66 or newer 292 engine that has a starter problem. When I bought the truck the starter did work but one of the bolt holes on the starter housing was broken out and the starter was hanging loose. I went to a junkyard and got another starter off a 292, bolted it up and the starter won't engage. It just clunks real bad. I changed the nose of the junkyard starter to the other starter with the broken nose, bolted it up and still have the same problem. The original starter had markings in paint, saying 70 Chevy 1-Ton 4 Sp V8. Did GM make two differant starters for differant flywheels? Help Please, Thanks in advance,
Ralph
