| | | Forums66 Topics128,292 Posts1,058,598 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76344 04/14/2007 8:16 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The port size is different between the two as I recall and as you mention the 235 used the rings. Beyond that there may not be much difference and if you can get the manifold to seal up to your head then I'd guess it would work fine. That "if" may be larger than it appears as it so often does. | | |
