| | | Forums66 Topics128,162 Posts1,057,058 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That seal is leaking Brad. Had the same trouble with mine when I first brought it home. It’s a lot of work to change it but these pictures might help. http://www.pbase.com/dennygraham/driveline As long as you're puking fluid out of that center support keep an eye on the trans fluid, it will suck a bunch out thru the rear bearing and you don't want to run it low. Denny Graham Sandwich, IL
Denny G Sandwich, IL
