It is a HEI, the instructions say to use the port on the carb that registers no vacuum at idle. I do not know what port that is, there are two ports on the front side that are plugged off by the PO.
(I'm not sure what ported or manifold means)
Alex
57' 3100 (The Bondo Bandit)
Bad rust and worse wiring, but so much fun.
