0 members (),
46
3
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 35 New Guy | | New Guy Joined: May 2011 Posts: 35 | I just had a set of Firestone LT radials installed on my 1952 3100. I asked for tubes to be installed but the tire tech said the rims were in good shape and tubes were not needed. However, they did say that adding tubes would have not been a problem if they were needed. Given the speeds at which we drive out trucks, I don't see excessive heat as an issue.
I would recommend some clear silicone sealant. I've used it on the inside of my wire wheels (tubes with radial tires) on my 67 MGB to seal the spoke heads. Works great.
1952 3100
Entire Thread
Wheel issues, Help!
| Tate | 06/10/2011 12:50 AM |
Re: Wheel issues, Help!
| DrewP | 06/10/2011 12:56 AM |
| LONGBOX55 | 06/10/2011 2:29 AM |
| tclederman | 06/10/2011 3:07 AM |
| LONGBOX55 | 06/10/2011 3:30 AM |
| Tate | 06/11/2011 1:34 AM |
| Roy Rodgers | 06/11/2011 2:48 AM |
| 40casey | 06/11/2011 2:56 AM |
| LONGBOX55 | 06/11/2011 3:07 AM |
| WE b OLD | 06/11/2011 2:17 PM |
| tclederman | 06/11/2011 3:34 PM |
| BC52 | 06/11/2011 3:52 PM |
| squeeze | 06/11/2011 4:34 PM |
| tclederman | 06/11/2011 6:34 PM |
| squeeze | 06/11/2011 6:58 PM |
| Tate | 06/12/2011 7:34 PM |
| Hotrod Lincoln | 06/12/2011 10:22 PM |
| SC3100 | 06/14/2011 11:43 AM |
| Tate | 06/17/2011 1:25 AM |
| Jianis | 06/12/2011 7:50 PM | |
