8 members (NJC, cmayna, Hotrod Lincoln, lumbersawyer, JW51, 3B, cshades, 1 invisible),
100
6
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Hi The G61 is on the block towards the bottom, on the starter side. It is just to the front of the CON3. Does it make a difference if it is on the block?
I looked at the link you sent for the casting numbers and came away only slightly less confused than when I started and that is why I posted my question.
Thanks for your help. I had no idea what I had. Peter | | |
