3 members (Peggy M, Jeff Ogden, 1 invisible),
43
8
Mod | | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | After re-reading the original post, I beleive what is being delat with are single peice wheels, rather than the 2 peice split rim. I noticed that it's mentioned that they are leaking around the rivets. Sounds like they might be loose. I have heard of guys peening the tight to get them to stop leaking. You may also consider seeing if you have anyone in the area that can install a vulcanized rubber band in the drop part of the rim, like they do on tubeless wire wheels, to seal them up.
Bill Burmeister | | | |
Entire Thread
Wheel issues, Help!
| Tate | 06/10/2011 12:50 AM |
Re: Wheel issues, Help!
| DrewP | 06/10/2011 12:56 AM |
| LONGBOX55 | 06/10/2011 2:29 AM |
| tclederman | 06/10/2011 3:07 AM |
| LONGBOX55 | 06/10/2011 3:30 AM |
| Tate | 06/11/2011 1:34 AM |
| Roy Rodgers | 06/11/2011 2:48 AM |
| 40casey | 06/11/2011 2:56 AM |
| LONGBOX55 | 06/11/2011 3:07 AM |
| WE b OLD | 06/11/2011 2:17 PM |
| tclederman | 06/11/2011 3:34 PM |
| BC52 | 06/11/2011 3:52 PM |
| squeeze | 06/11/2011 4:34 PM |
| tclederman | 06/11/2011 6:34 PM |
| squeeze | 06/11/2011 6:58 PM |
| Tate | 06/12/2011 7:34 PM |
| Hotrod Lincoln | 06/12/2011 10:22 PM |
| SC3100 | 06/14/2011 11:43 AM |
| Tate | 06/17/2011 1:25 AM |
| Jianis | 06/12/2011 7:50 PM | |
