| | | Forums66 Topics128,016 Posts1,055,337 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | Installing a 350 engine will require converting to a 12 volt system. Stock 1950 chevies have a closed driveline. The entire drive train will need updating. Do not forget the brakes. More power needs better a breaking system for a safe truck. As said above the gauges are the least of the issues for the change. | | |
