| | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | To see if it turns over no key, ignition switch, or hot wire is necessary. Just press the foot starter button on the floor.
For it to run (and all the lights to work) connect together all the wires on the back of the ignition switch. Note that this hot wire method works because the starter is not a function of the key switch.
Grigg | | |
