1 members (Peggy M),
131
2
Mod | | | Forums66 Topics128,105 Posts1,056,538 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75108 03/20/2007 2:28 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Usually it means the number of bolts holding the ring gear onto the differential case in GM products, the more bolts the larger the ring gear diameter & strength should go alone w/that. Ring gear diameter is usually used to ID for parts actually. And yes, I hear alla time "that's a 10-bolt cause theres 10 bolts on the cover" when its actually a Dana rearend. Brian | | | |
Entire Thread
10 bolt, 12 bolt, 14 bolt, whaaa???
| Denny Graham | 03/20/2007 2:22 PM |
Re: 10 bolt, 12 bolt, 14 bolt, whaaa???
| 64fleetside | 03/20/2007 2:28 PM |
| BIG CHEVY 3600 | 03/20/2007 10:58 PM |
| rusthater | 03/20/2007 11:37 PM |
| carolines truck | 03/21/2007 12:00 AM |
| OldSub | 03/21/2007 2:32 AM |
| Denny Graham | 03/21/2007 4:04 AM |
| OldSub | 03/21/2007 6:07 AM |
| 5wests | 03/21/2007 7:12 AM |
| truckernix | 03/21/2007 11:31 AM |
| Achipmunk | 03/21/2007 4:02 PM |
| mummdogg | 03/21/2007 4:09 PM |
| Denny Graham | 03/23/2007 1:14 PM | |
