7 members (Bill Hanlon, Brian Moore, TUTS 59, Ponchogl, sron48, Steelonsteel, 1 invisible),
82
3
Mod | | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Cleaned the old pump and put an additional in-line filter on the gas line and installed the pump. So I think. Put it in place and could finger tighten the bolts until they were seated. There was a bit of tension on the pump from the diaphram lever. Took forever to start and when it did there was a loud "whomp-whomp" sound from the engine. I figure installing the pump is fairly simple but is it? Is it possible the lever is on the wrong side of the came lobe or is that impossible. Did one once before on a 216 and it was fine. This is a 235. | | |
