Put the timing mark at zero, take the distributor cap off, turn the dizzy to line up rotor tip on #1. Should be easy to turn the dizzy cause I suspect your hold down bolt has loosened. I had the same problem. Timing kept changing till I figured out the clamp with the bolt going thru it was on wrong.
