| | | Forums66 Topics128,095 Posts1,056,077 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That sounds like the problem but it is rare on that engine. They dont use achain but the 250 comes out with a fibre cam gear. Take the valve cover off & check the location of the valves when at TDC. When you are at TDC the valves on #6 Or #1 should be overlapping. Like the exhaust closeing & the intake opening. If that is correct then your dist. has jumped time. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
