9 members (MickeyP, papas52, Biermann, Otto Skorzeny, Donf, jmoore, Shade Baby, TS3600, BC59),
118
2
Mod | | | Forums66 Topics128,162 Posts1,056,949 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | I like the very thin snowflake-shaped lockwashers for flywheel bolts, particularly if you can find the ones with smooth outer edges and the teeth pointing inboard. A drop or two of blue LocTite can't hurt, whether or not lockwashers are used. Be sure all the holes are filled, or you'll get oil leakage from the crankcase into the clutch housing. Jerry
