DANGER DANGER
LOL I hear ya Dr. Smith!
I concur the CG is better up close to the vertical support.
The bell housing definitely pushes the CG farther out, the depth of the housing. I extended the legs on my stand to compensate.
Actually this has worked for me, since I used the flywheel to turn the engine for putting in the pistons and setting up my timing. I was more concerned with the strength of the bolts holding onto the bell housing...
I DO appreciate your concern. Pray for me, I'm almost finished with the entire assembly!
Joe! Don't listen to me... unless you modify your stand...ha. eeeek
My friend Hotrod is my Guru! He won't steer you wrong.
