| | | Forums66 Topics128,089 Posts1,056,433 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | if you are pulling out a 230-250 6-cly motor you can use your old frame mounts, and use the rubber mount that are bolted to them, just take the mount apart and bolt the rubber mount to your block, if it is a 292 6-cly you will need the passenger side frame mount. Very easy install. email me if you still need pictures. [email protected] | | |
