| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Adam, do you see a pivot above or below the shaft on your pto ? The pto on my '36 1.5 ton has a bolt above the pto where the linkage hinges. Other than that it is just a simple lever made of flatstock that is offset to keep it close to the trans. shifter. | | |
