2 members (BC59, Danielbolt),
210
3
Mod | | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | The spring closes the heat valve in the exhaust manifold to direct exhaust heat right up under the carb for faster and more efficient cold starts. As the engine warms, the spring relaxes and backs off the valve. You still get some heat to the carb base with it not working, and in some warmer climates, you can get away with that all year long. If you are in colder climates, you should see about getting it fixed or replaced. Start by working the valve in the exhaust manifold. Use lots of solvent and slowly work it each day till it becomes free enough to rotate. Some of the venders in the LINKS above sell new springs.
Joe | | | |
Entire Thread
Idle Speed/mix Adjustments, Dies on deceleration
| MLT | 03/22/2011 6:09 PM |
Re: Idle Speed/mix Adjustments, Dies on deceleration
| truckernix | 03/22/2011 8:03 PM |
| MLT | 03/23/2011 12:22 AM |
| truckernix | 03/23/2011 12:35 AM |
| MLT | 03/23/2011 12:52 AM |
| joker | 03/23/2011 1:07 AM |
| truckernix | 03/23/2011 11:42 AM |
| MLT | 03/23/2011 3:14 PM |
| Joe H | 03/23/2011 3:43 PM |
| MLT | 03/23/2011 8:29 PM |
| Joe H | 03/24/2011 3:49 PM |
| MLT | 03/25/2011 1:22 AM | |
