8 members (Ridgeback, GMCJammer51, Biermann, Danielbolt, sron48, GIJOE298, Phak1, DadsFirstPickup),
111
3
Mod | | | Forums66 Topics128,154 Posts1,056,835 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | The mixture screw is what you were turning while holding the gauge. This adjusts the fuel to air ratio during idle and just off idle right before the main metering circuit takes over. As you went in with the screw you leaned out the mixture enough the engine couldn't run. Backing it back out the mixture became richer. As stated above, you should be in the 1 1/2 to 2 turns out from the seated position of the screw.
If its starting with out touching the throttle you are very close, a 1/4 turn either way should effect its starting, better out, worse in.
The throttle shaft is where the linkage hooks to, if it can be wiggles around a lot, then the bushings are worn out. No need to remove anything to check it.
Joe | | | |
Entire Thread
Idle Speed/mix Adjustments, Dies on deceleration
| MLT | 03/22/2011 6:09 PM |
Re: Idle Speed/mix Adjustments, Dies on deceleration
| truckernix | 03/22/2011 8:03 PM |
| MLT | 03/23/2011 12:22 AM |
| truckernix | 03/23/2011 12:35 AM |
| MLT | 03/23/2011 12:52 AM |
| joker | 03/23/2011 1:07 AM |
| truckernix | 03/23/2011 11:42 AM |
| MLT | 03/23/2011 3:14 PM |
| Joe H | 03/23/2011 3:43 PM |
| MLT | 03/23/2011 8:29 PM |
| Joe H | 03/24/2011 3:49 PM |
| MLT | 03/25/2011 1:22 AM | |
