| | | Forums66 Topics128,188 Posts1,057,218 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | you need to remove the dowel pin first. then you need to drive out the shaft that the pedal rotates on. the you need to drive out the old brass bushing and reverse sequence when reinstalling everything. my truck was always garage kept plus with all the oil and grease that the parts are caked luckily with mine the pin and shaft came out fairly easy. what ever you do dont break any of the castings in the removal process. the clutch pedal should have a push/pull pin and thats an easy one at least thats how it is on my 40. | | |
