| | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | Grigg -- Measurements off Ole Charlie:
In stock configuration, running 7.50x19 tires
Outside of sidewall to outside of sidewall: 65 11/16" Top of wheel sidewall to fender opening (top): 3 1/2"
Turning clearances
front of fender opening: 2 1/2" Back of fender opening: 2"
At full throw (wheels at full turn), the tire is 1 3/4" from the rear springs (limiter at front is the shock (single action) and the clearance appeared to be 5 or 6 inches or more).
If you need more, let me know. Looks like I came within spittin' distance of Ghostrider's radial-equipped truck (beautiful truck BTW!) But I think you have less than 2 inches to play with before you run out of schlitz on the wheel opening.
Thanks for the support Steve Sr.!
Hope this helps.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
