| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I'm assuming this is a key-start truck? Possibly a problem in the ignition switch that's sending voltage to the solenoid during turn-off. You could check it with a trouble light on the starter solenoid terminal that comes from the switch, if you see a momentary light during shut-down, you've got a problem in the switch or something is wired wrong. | | |
