2 members (Tinker5, klhansen),
178
3
Mod | | | Forums66 Topics128,195 Posts1,057,369 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Thanks Spanky, 4,500 lb sounds good, so I shouldn't worry about that. By keeping the original I-beam and king pins 4,500lb should still be the nominal rating, but it'll have wheel bearings and brakes that would handle 6,000 lb Well, I figured it was a 2 ton because the front hub caps bolt on with 6 bolts. But then again I was quite surprised to find only a single speed rear axle. Guess I should look at the tag on the door and translate.. Thanks for the offer John, but I think I'll stick with the GMC axle, no narrowing necessary. This should be about the simplest and cheapest method for disc brakes, 22.5" wheels, and still fit under the fenders. Grigg And yep, I like the wrench too, have a couple dozen on order  | | | |
Entire Thread
1953 GMC, Detroit, Roadranger, disc brakes, and PS!
| Grigg | 01/23/2011 11:22 PM |
Re: 1953 GMC, Detroit, Roadranger, disc brakes, and PS!
| HevyHauler | 01/24/2011 1:14 AM |
| crenwelge | 01/24/2011 2:45 AM |
| davesmith | 01/24/2011 2:54 AM |
| John Milliman | 01/24/2011 3:04 AM |
| HevyHauler | 01/24/2011 4:56 AM |
| crenwelge | 01/24/2011 6:38 AM |
| Grigg | 01/24/2011 2:36 PM |
| Grigg | 01/24/2011 2:49 PM |
| crenwelge | 01/24/2011 6:33 PM |
| Grigg | 01/24/2011 7:12 PM |
| HevyHauler | 01/25/2011 5:51 PM |
| HevyHauler | 01/25/2011 6:09 PM |
| Grigg | 02/13/2011 12:53 AM |
| crenwelge | 02/13/2011 1:11 AM |
| Grigg | 02/13/2011 1:19 AM |
| Grigg | 02/13/2011 3:43 PM |
| spanky | 02/13/2011 3:46 PM |
| John Milliman | 02/13/2011 4:06 PM |
| Grigg | 02/13/2011 4:49 PM |
| Grigg | 02/23/2011 7:13 PM |
| 3B | 02/24/2011 2:31 AM |
| Grigg | 02/24/2011 3:25 AM |
| Grigg | 02/25/2011 10:10 PM |
| 3B | 02/26/2011 1:43 AM |
| 3B | 03/01/2011 4:39 PM |
| Grigg | 03/01/2011 5:18 PM |
| Grigg | 03/04/2011 2:20 AM |
| Grigg | 04/26/2011 4:14 PM |
| Grigg | 04/27/2011 2:26 AM |
| SimS | 04/27/2011 12:16 PM |
| Grigg | 04/27/2011 1:49 PM |
| Napco Man | 04/27/2011 3:47 PM |
| SimS | 04/27/2011 4:19 PM |
| Grigg | 04/27/2011 5:46 PM |
| Grigg | 04/28/2011 8:33 PM |
| Grigg | 05/03/2011 2:31 AM |
| Grigg | 05/04/2011 1:25 AM |
| Grigg | 05/05/2011 1:57 AM |
| Grigg | 05/05/2011 4:11 AM |
| crenwelge | 05/05/2011 5:03 AM |
| Grigg | 05/05/2011 12:21 PM |
| kb3csw | 05/05/2011 12:45 PM |
| Grigg | 05/05/2011 1:40 PM |
| crenwelge | 05/05/2011 5:25 PM |
| Grigg | 05/05/2011 5:56 PM |
| Grigg | 05/06/2011 11:11 PM |
| HevyHauler | 02/13/2011 8:03 PM |
| Rick In VA | 02/14/2011 4:20 AM |
| Grigg | 08/21/2013 11:04 AM |
| 3B | 08/21/2013 3:38 PM |
| Grigg | 08/22/2013 9:18 AM |
| Grigg | 08/23/2013 9:58 AM |
| crenwelge | 08/23/2013 3:59 PM |
| HevyHauler | 08/24/2013 11:54 PM |
| Grigg | 08/27/2013 9:28 AM |
| crenwelge | 08/29/2013 1:11 AM |
| Grigg | 08/29/2013 9:47 AM |
| crenwelge | 08/29/2013 10:33 PM |
| Bill Marlow | 08/30/2013 5:45 AM |
| Goob | 08/30/2013 11:47 AM |
| Grigg | 08/30/2013 1:27 PM |
| Goob | 08/30/2013 10:18 PM |
| HevyHauler | 08/31/2013 4:05 AM |
| Grigg | 09/02/2013 7:45 PM | |
