First of all, any stock SBC HEI should fit your 283 perfectly.
Run a new 12GA wire from the spare switched terminal on the fuse box to the right hand terminal on the "wire tab" on the cap. Bypass the original ignition resister, it is no longer needed. You also need to replace the plug wires with an HEI compatible set. I suggest that you tell a parts house you want plugs and wires for a 1976 350 in a C10. Gap the plugs for the HEI at around .045. Retime your engine with the new distributor and enjoy your new HEI!
Best wishes,
Les
