| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | I have a 1954 3600 that had no heater. I found a restorable one (fresh air type) but it does not have the underdash bracket for the flexible cable that operates the inside/outside vertical door. It does have has the correct bracket for the temp control rod.
Question: any idea where to find a correct bracket for the flex cable that mounts left of the steering wheel? Or, Plan B, the temp control rod brackets seem more common. Can I adapt one of those to use for the flex cable?
Any help would be appreciated. Thanks.
Harry | | |
