| | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 76 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 76 | I purchased a T5 out of a V8 86 Camaro with a speedo cable & than purchased just the S-10 tail piece to change the gear shift location to fit behind a V8 in my 38 truck. My question is how to I change the location of the speedo gear & mount on the tail shaft in the correct location? There is a flat spot on the tail shaft but no holes or clip grooves. The gear also has a larger ID than the shaft OD. I think I can add shim stock to make up the distance but how do I mount the gear? & what about balance | | |
