| | | Forums66 Topics128,005 Posts1,055,254 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71407 01/10/2007 6:26 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | You need heat to provide vaporization of fuel and to prevent carb from freezing up. Carbs can freeze up on a 100+ degree day. Also needed to improve performance and save gasoline. The only situation where heat is not needed is on the salt flats where the engine is consistently operated with the throttle wide-open.
On the other hand if you are using exhaust heat without the heat riser thermostatic spring fully functional you will have too much vaporization, poor combustion, poor performance, and wasted fuel. In addition your carbs will eventually be destroyed from being way too hot for extended periods of time.
Mike Barnes 1950 GMC 1-ton pickup
Entire Thread
Heat Riser...?
| WHO, ME ? | 01/10/2007 1:29 AM |
Re: Heat Riser...?
| rustednuts | 01/10/2007 2:32 AM |
Re: Heat Riser...?
| 50GMC253 | 01/10/2007 6:26 PM |
Re: Heat Riser...?
| WHO, ME ? | 01/11/2007 1:04 AM |
Re: Heat Riser...?
| Tiny | 01/11/2007 1:29 AM |
Re: Heat Riser...?
| WHO, ME ? | 01/11/2007 1:43 AM |
Re: Heat Riser...?
| Truckstein | 01/11/2007 2:28 AM |
Re: Heat Riser...?
| WHO, ME ? | 01/11/2007 2:58 AM |
Re: Heat Riser...?
| 50GMC253 | 01/12/2007 5:24 PM |
Re: Heat Riser...?
| WHO, ME ? | 01/12/2007 7:24 PM |
Re: Heat Riser...?
| 50GMC253 | 01/12/2007 10:20 PM |
Re: Heat Riser...?
| WHO, ME ? | 01/13/2007 12:19 AM |
Re: Heat Riser...?
| rustednuts | 01/13/2007 2:39 AM |
Re: Heat Riser...?
| ken 270 | 01/13/2007 5:45 AM |
Re: Heat Riser...?
| WHO, ME ? | 01/13/2007 5:46 AM |
Re: Heat Riser...?
| Beaver 53 | 01/14/2007 3:05 AM |
Re: Heat Riser...?
| RAC1812 | 01/16/2007 12:39 AM |
Re: Heat Riser...?
| Flxible | 01/16/2007 1:10 AM |
Re: Heat Riser...?
| Holcomb | 01/18/2007 5:00 AM |
Re: Heat Riser...?
| WHO, ME ? | 01/18/2007 5:10 AM |
Re: Heat Riser...?
| Holcomb | 01/18/2007 8:39 PM |
Re: Heat Riser...?
| WHO, ME ? | 01/18/2007 8:52 PM |
Re: Heat Riser...?
| Holcomb | 01/18/2007 11:58 PM |
Re: Heat Riser...?
| WHO, ME ? | 01/19/2007 3:50 AM |
Re: Heat Riser...?
| Brendan M | 01/19/2007 4:57 AM |
Re: Heat Riser...?
| Holcomb | 01/19/2007 5:17 AM |
Re: Heat Riser...?
| WHO, ME ? | 01/19/2007 6:45 AM | |
