No I dont have access to a lathe large enough.. we can only clear about 16" on the lathe we have
But I have access to a Bridgeport with a turn table.. as long as I can indicate the rim centered on the turn table I should be good... I have already created a plate with the appropriate 4.75" diameter and some mounting holes. Plan is to indicate that center on the turn table and then locate the rim off the hub hole as it would be on the truck....
two votes for no flaps.. Ill go no flaps then!
