2 members (baldeagle, CuzzFuzz),
27
0
Mod | | | Forums66 Topics128,003 Posts1,055,245 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I suppose having the carb reasonably level is a good idea... But the critical part is the U-joint angles. Here's a driveline setup tech tip with some good links. http://www.stovebolt.com/techtips/driveline/setup/index.htmlLikely you can have both a level carb (if it matters) and correct driveline angles, but no question about it I'd favor the correct driveline angles. Grigg | | |
