| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70648 12/27/2006 5:22 PM | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | If you go with a PCV system you MUST use a filter with a collector and drain. You can make one yourself but they are also available online. It works by condensing the heavy crankcase fumes into liquid form inside the filter canister. It fills up really quick and needs to be drained every few hundred miles. You have to see for yourself how much nasty stuff the crankcase produces. You would never introduce this into your intake on purpose.
Despite the filter a pcv system will produce a hard crusty build up inside the combustion chambers after a few thousand miles already, decreasing performance. Another drawback with these systems is they stop working when the engine produces most of the crankcase vapors - under heavy load or prolonged high rpm. Without the road draft tube, the increased crankcase pressure in these conditions is hard on the seals and rings, let alone escaping oil vapor makes a constant mess of a clean engine.
I have used a filtered closed PCV system daily for a few years and am now going back to the road draft tube with a dedicated valve cover filter. I found that crankcase vapors shouldn't be anywhere near the intake of my engine and that increased pressure on the freeway needs to be evacuated. If the road draft tube can't do this efficiently, I may use the exhaust as the last resort. There are crankcase evacuation kits available online where the exhaust sucks out the vapor pressure at higher rpm and eases piston travel at the same time. | | | |
Entire Thread
Road Draft Tube
| WHO, ME ? | 12/27/2006 6:34 AM |
Re: Road Draft Tube
| tclederman | 12/27/2006 6:53 AM |
Re: Road Draft Tube
| WHO, ME ? | 12/27/2006 7:16 AM |
Re: Road Draft Tube
| Fred T | 12/27/2006 7:19 AM |
Re: Road Draft Tube
| WHO, ME ? | 12/27/2006 7:56 AM |
Re: Road Draft Tube
| On the road | 12/27/2006 5:22 PM |
Re: Road Draft Tube
| doc41 | 12/27/2006 5:44 PM |
Re: Road Draft Tube
| WHO, ME ? | 12/27/2006 5:51 PM |
Re: Road Draft Tube
| Rattletrap 52 | 12/27/2006 5:53 PM |
Re: Road Draft Tube
| WHO, ME ? | 12/27/2006 6:05 PM |
Re: Road Draft Tube
| On the road | 12/27/2006 6:12 PM |
Re: Road Draft Tube
| Tiny | 12/28/2006 1:43 AM |
Re: Road Draft Tube
| WHO, ME ? | 12/28/2006 2:37 AM |
Re: Road Draft Tube
| doc41 | 12/28/2006 3:42 PM |
Re: Road Draft Tube
| Builder | 12/28/2006 6:52 PM |
Re: Road Draft Tube
| WHO, ME ? | 12/28/2006 9:25 PM |
Re: Road Draft Tube
| doc41 | 12/28/2006 11:41 PM |
Re: Road Draft Tube
| WHO, ME ? | 12/29/2006 12:27 AM |
Re: Road Draft Tube
| tclederman | 12/29/2006 12:51 AM |
Re: Road Draft Tube
| Beaver 53 | 12/29/2006 1:09 AM |
Re: Road Draft Tube
| WHO, ME ? | 12/29/2006 1:46 AM |
Re: Road Draft Tube
| tclederman | 12/29/2006 2:02 AM |
Re: Road Draft Tube
| WHO, ME ? | 12/29/2006 2:07 AM |
Re: Road Draft Tube
| WHO, ME ? | 12/29/2006 2:20 AM |
Re: Road Draft Tube
| tclederman | 12/29/2006 4:35 AM |
Re: Road Draft Tube
| WHO, ME ? | 12/29/2006 4:49 AM |
Re: Road Draft Tube
| WHO, ME ? | 12/29/2006 5:07 AM |
Re: Road Draft Tube
| doc41 | 12/29/2006 2:08 PM | |
