2 members (Phak1, Tom McGrath),
119
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70415 12/22/2006 7:47 PM | | Anonymous Unregistered | | Anonymous Unregistered | GM transmissions all have unique pan configurations so you can identify that component rather easily. The engine will have a number on the upper left flange of the bell housing that will ID the engine in a general sense. The right front side (passenger) of the engine block just behind the altenator will have a small rectangular land area on which should be stamped a series of characters/numbers. If the block has not been decked in the past these should still be there but may be under a layer of crud. If you find those characters there are several sites that define what these engine codes/suffices designate. | | |
