Originally Posted by Oilrag
Jerry,
There is also a stamped number on the pad to the rear of the distributor. Can you post that info. Should be something like F106J. This will tell you the assembly plant, month and day, and the truck series number.
Sorry to be so late with this reply. hopefully you or someone can decipher this code:
F112 s K
I get Flint, Jan. 12'th, Not sure of the rest.
