| | | Forums66 Topics128,151 Posts1,057,009 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Depends on what your intentions are? Are you going to go with stick or automatic? Do you know what ratio it is? Have you measured it for width? What wheels do you plan to use? Are you going to pull, haul, or just a driver? I have a 79 Camaro rearend under my Burb, they all need some fabrication! | | |
