7 members (Phak1, moparguy, Chooglin, 54farmtruck, 2-Ton, GMCJammer51, WICruiser),
47
Mod | | | Forums66 Topics128,151 Posts1,057,004 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | i have a 79 nova that is going to the junk yard. The rear end is still in it and im wondering if i can use it for my truck a 53 chevy 3100. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Depends on what your intentions are? Are you going to go with stick or automatic? Do you know what ratio it is? Have you measured it for width? What wheels do you plan to use? Are you going to pull, haul, or just a driver? I have a 79 Camaro rearend under my Burb, they all need some fabrication! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It should be a 10 bolt and it will fit. If you don't like the ratio you can pick up one you prefer on Ebay. You can also bolt on 2002 CAMARO TRANS AM 12" LS1 REAR DISC BRAKES if you want to.
~Jim
