The Saginaw 4 speed was popular in the early to mid sixties Chevy full sized cars-Impala and such. Good transmissions;bolt right up to the 3 speed bellhousings,same clutch splines,and there's an adapter kit available to hook one up to a Torque-Tube drive. I've also heard rumors of using the overdrive output shaft and tailshaft housing,to give you a 4 speed with overdrive. that'd be the best of both worlds!
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
1952 Chevy 6400 dump bed project truck
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
