You can use the head bolt hole for the alternator, there should be one in back also. The important thing is good bolts and using as much thread as possible. Have the bolt tight. I usually pull both engine and trans if the front is clear. Having the trans crossmember out does make it easier but not always nessesary. Good luck.
Rapper1
