| | | Forums66 Topics128,042 Posts1,055,602 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | You will possibly need to remove the plug from the ezyloom and install insulated crimp/solder terminals. Dip switches have 3 connections (most common) one is fed from your headlight switch and the other 2 are for low / high beams connections. Trial and error maybe required none of this should create any smoke. regards andrew | | |
