The way I understand it, the 307 is the piston to use because almost same as 250 except flat top and just a few thousands short of deck height. The 283 is not used because it has a shorter distance from pin to top of piston, therefore would be too short in cyl..
Am I correct?
Stock 250 piston is dished about .085" also.
What cam for street driving? Stock or a RV grind?
Just my Thoughts,
Walt
