1 members (Hotrod Lincoln),
105
2
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Drill one out and measure the hole diameter. Your replacement rivet should protrude 1.5x diameter to produce the correct size head after setting it.
If you've never driven a rivet you are in for a surprise as to exactly how much force it takes to drive one. Tubular rivets take less force but require specialized tools to set properly.
I doubt that replacing them with screws would hurt anything beyond aesthetics, but that's up to you. | | |
