| | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68795 11/18/2006 6:56 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 1 - drain hole, in case of rear main leak and to let water out that enters from the front hole, where the timing ball is seen 2 - no - turn the engine over by hand until you see the timing mark in the small hole, passenger side [turns easy w/ plugs out] 3 - ? 4 - copper works
Bill | | |
