I am trying to figure out where my distributor vacuum line goes. I have a 1960 283 with a Rochester 2G carb. The vacuum line was hooked up to manifold vacuum when I got the engine. The only vacuum port I find on the carb is a large one in the throttle plate thet appears to be for power brakes. I did find another brass screw in plug just below where the fuel line goes in. it appears to be a place to get ported vacuum but I am not 100% certain it is a vacuum port. Anybody know? I can not fire the engine up to test it.
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
