| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | There's nothing wrong with the lubrication system on a 216- - - -as long as the oil clearance on the connecting rods is correct and the "squirters" that supply oil to the rods above idle speed are aimed correctly. Babbit rod bearings are pretty rugged as long as they're lubed properly, and they aren't allowed to hammer themselves to death with excessive clearance. Drop the oil pan and inspect the crankshaft journals, and adjust the oil clearance with shims to .002" or slightly less. As long as the rod journals are smooth and round, and the rod clearance is right, drive on! Jerry
