Thanks everyone for your advise!
Does the heli-coil come for a specific size bolt or are they generic? The old one came out wrapped around the head bolt.
I started taking the front end off "The Truck" in preparation to pull the motor. I'll put it in the shop for the winter (once I make rooom, bigger project than rebuilding)
Scott I might take you up on the offer. I will be traveling up 35W to Duluth for my next Grandchild's birth sometime around Jan. Maybe on the return I could swing over.
Thanks again for your help.
