| | | Forums66 Topics128,282 Posts1,058,496 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | The most common swap when going to the internal-regulated alternator is the Delco 10-SI series. It's available in amp capacities from about 55 to 100+ depending on the donor vehicle. It's slightly larger in diameter than the external regulated alternator, but a simple tensioner bracket change is usually all that's needed to make the swap. Wiring is ridiculously easy- - - -just install the same battery wire you took off the original alternator,and install a jumper wire from that terminal to the wire terminal marked #2 on the side of the alternator. If you want to use a dash-mounted idiot light, find the original wire from the dash that makes the idiot light illuminate when you ground it, and attach that one to the terminal marked #1. Cut away and tape any leftover wires, including the connector to the original regulator, and drive on! Jerry
