| | | Forums66 Topics128,282 Posts1,058,496 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 28 New Guy | | New Guy Joined: Sep 2010 Posts: 28 | Hello all , I have started the project of bring back a 65 P30 van . I'm getting to be all over this site as more problems arrive on this project . The latest in the list of failures is the alternator , or at least the regulator , maybe both . Seeing as to how the alternator is very small being under 40 amps , and isn't the correct one for the engine as well , (pulleys do not line up) I was thinking it would be better to up-date the system to an internal regulated system and try for a 80 amp alternator . Anyone have any tips about what needs to be changed in order to make this swap ? Can the same mounts be used ? Any major wiring changes needed ? Is it worth the trouble ? Thanks for any advice . I now need to head over to the suspension section for help in that area . Sure is great having all this information in one location . | | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | The most common swap when going to the internal-regulated alternator is the Delco 10-SI series. It's available in amp capacities from about 55 to 100+ depending on the donor vehicle. It's slightly larger in diameter than the external regulated alternator, but a simple tensioner bracket change is usually all that's needed to make the swap. Wiring is ridiculously easy- - - -just install the same battery wire you took off the original alternator,and install a jumper wire from that terminal to the wire terminal marked #2 on the side of the alternator. If you want to use a dash-mounted idiot light, find the original wire from the dash that makes the idiot light illuminate when you ground it, and attach that one to the terminal marked #1. Cut away and tape any leftover wires, including the connector to the original regulator, and drive on! Jerry
| | | | | Joined: Sep 2010 Posts: 28 New Guy | | New Guy Joined: Sep 2010 Posts: 28 | Sounds easy enough . Thanks for the tip . | | |
