| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67915 10/27/2006 9:15 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The other 2 bolst are inside the bellhousing. You'll have to remove the sheetmetal cover from the bottom of the bellhousing to get to them. The remaining 4 bolts that attach the bellhousing to the block are accessed the same way, after the clutch and flywheel are removed.
Bill Burmeister | | |
