| | | Forums66 Topics128,159 Posts1,056,901 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67914 10/27/2006 9:06 PM | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | When I pulled the engine the other day, I left the tranny on because I couldn't get it disconnected.. I just removed pretty much everything from the engine (carb, maniford, starter, etc) and all I really have left to remove now is the tranny... How the crap does the transmission unbolt from the engine? I see 2 bolts at the top of the transmission connecting to the engine, but it looks like its 1 solid piece.. but I know it's not! Frustrating! How many bolts connect the tranny to the engine.. where are they?????
1952 Chevy 5 Window Restoration
#67915 10/27/2006 9:15 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The other 2 bolst are inside the bellhousing. You'll have to remove the sheetmetal cover from the bottom of the bellhousing to get to them. The remaining 4 bolts that attach the bellhousing to the block are accessed the same way, after the clutch and flywheel are removed.
Bill Burmeister | | |
#67916 10/27/2006 11:26 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | pull the transmission from the bellhousing first....then pull pressure plate, clutch, and flywheel...then pull bellhousing from engine... | | |
#67917 10/29/2006 4:03 AM | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | This is a pain.. the way I have it, its hard to get to the bottom of the bellhousing to get to the bolts for the tranny... I still have it hanging from the hoist with a chain wrapped around it. I need to get all of this removed and get that engine put over onto my engine stand...
#67918 10/29/2006 4:15 AM | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | Well, the chain is wrapped around it, but it's sitting on a wood pallet thing....
#67919 10/29/2006 6:25 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Roll it on its side and proceed. Remove the distributor and fuel pump first if you lay it on that side. | | |
