There is lots of information written in this forum about OD's.
My recommendation would be to pick up a 55-59 shop manual which has all the information needed, wiring diagram, trouble shooting, etc. GM used OD's from 55-69 in cars and trucks.
In addition to the solenoid you should have a govenor (mounted on the rear housing) pull cable, kick down switch, relay, and wire loom.
Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes
1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes
2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans
1947 Willys CJ2A w/F-Head engine
