| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Welcome to the Stovebolt aj. Your best bet if you're looking for more speed would be to focus on the rear end gearing first. In most cases that would be the easyest and least expensive place to start. If that doesn't get you on the autobahn then you might look into converting to one of the five speed transmissions like a T5 manufactured by Borg Warner Automotive. Just for starters try researching in links similar to this http://www.5speeds.com/t5/ Stick with us, don’t be shy about asking more questions and the guys here will get you up to speed. Denny Graham Sandwich, IL USA
Denny G Sandwich, IL
