I'm back. I've got my horn to work as orginally designed with ground circuit in stering column. My problem is when I begin to turn wheel the contact spring/bushing under horn contact plate slides off the brass hub below it. I've seen plastic housed horn contact bushing, is this the fix? My original spring contact thing keeps jumping off brass hub, and horn goes off.
Bruce
